Thanks Paul. Hadn't even thought of that. The colder the battery is, the slower the charge will be. So it'll *eventually* charge up, but it might be three or four times longer than in a temp of around 60F.
Manufacturers (Ford for example) recommend keeping the car in a heated garage in the winter - and not parking outside when you're on a drive. So spending an hour in Home Depot in the winter, leaving the car in the parking lot, isn't a good idea if the battery will need charging.
And unfortunately, charging an EV in cold weather actually reduces the batteries' power forever by chemically altering the lithium.
yeesh yeesh
yeesh yeesh
Hi Guest!
