ethanol gasoline
  • Thread starter Thread starter Guest
  • Start date Start date
G
up here in the north country we have ethanol in our gas. Just wondering if anyone out ther has had a problem with thi type of alcohol. Just filled up and found a gas leak in a fles fuel line. Am I alone here. The mix is just 10% ethanol. Just asking as I have heard other horror stories. Bill
Bill, I've been running the 10% ethanol mix in a '72 Midget for at least 8 years, and have had no fuel related problems whatsoever that I could attribute to the gasoline used. As a matter of fact, the only fuel system problem I've had was a leaking fuel pump, shortly after I put the car back on the road. It had been sitting for 13 years, and the seals at the pump fittings had dried out.
The fuel system is entirely stock.
Jeff
