Engine won't start
Dono
Hi All,
1971 Spit rebuild. All together but won't start and would appreciate ideas.
1. Fuel pump okay, fuel getting into carb.
2. Carb rebuilt prof by Joe Curto/NY, so s/b okay.
3. Electronic ign w/ new coil; strong spark shows at plug when removed and grounded.
4. Timing is correct, not out by 180 deg. Valve & pistons checked visually for proper position relative to the rotor position.
5. Cyl compression on each is 148-150 lbs. Is this too high?
I'm stumped. Thanks, Dono
DNK
If you got good spark at the cy. and you say the timing is close enough it's gotta be that no volatile liquids are getting to the spark
Andrew Mace
I had a similar situation years ago with a Spitfire 1500. I finally decided to turn on the ignition, loosen the distributor and then turn it back and forth as I worked the starter solenoid button...until it caught and fired up! Not terribly scientific, but it worked for me.
I'm curious, though: After a lot of cranking and no firing, do you find that the plugs are wet with fuel?
Dono
Hondo, Andy,
Thanks for the ideas. I tried the carb fluid, engine 'burps' then quits. Carb float bowl is full. I'll try Andy's suggestion of loosening the carb and tripping the starter solenoid and see if I can get it to fire up.
I also wonder if the float bowl is letting gas into the intake jet/needle, since the plugs remain dry after cranking.
More to come, Don
DNK
Tom, maybe the volatile liquid ain't getting past the carbs. He says the plugs are dry.
Rhodyspit75
I know you said the timing wasn't out 180 degrees. Mine wasn't either and I had all the same problems. I had checked it and had a friend review it and we were 100% sure. Friend went home, I went in and had a beer. Found another article on timing printed that one, went back to the garage and lo and behold. I had been wrong ( I was on the wrong stroke) and the engine was running in 5 minutes.
TR4
If the plugs are dry after cranking, I would ask if the carb needle and jet were preset. Are they adjusted completely closed? Normally, they come back bench tested and set to install but there is a chance they were closed for return shipping.
Platinum
If Joe did 'em they were bench set.
Mebbe put a vacuum gauge on it first. Be somewhat informed as to whether or not you have an intake leak...
I'd be for putting a timing light on it. If the #1 plug is firing on (or near) the 8° mark, pull the wires from the cap and put 'em in 180° from where they are now. Whadd'll it hurt? Get a BIG backfire and a: "THAT didn't help much!" if its wrong. :shrug:
"95% of all carb problems are in the ignition." etc.
Dono
Engine won't start - Success !!
Greetings Brit-heads!
Success! Thanks to all for their valued ideas. So what was it? The timing,....no - well a bit since I have to yet put a timing light on it, it idles rough. The spark,...no. Unlike the old Sat movie serials, I'll not make you wait. It was the fuel. The carb was prof rebuilt by Joe Curto. Though fuel was getting into the carb, it was not leaving the float bowl. Inside the float bowl, the floats push up on a pin that shuts fuel into the carb. When low, the floats drop the pin, allowing fuel in. At the top of that pin assembly is a tiny mesh screen cap. It was barely passing air & no fuel. I pulled that off, reassembled it all, put starter fluid into the intake and after a couple turns it caught and continued to run - thus getting fuel thru to the needle. So add this as a possible cause of fuel starvation situations. I have to 2 in-line fuel filters, so I'm leaving that mesh cap off.
Have a great Sat and Father's Day! Dono
poolboy
Re: Engine won't start - Success !!
So you found that something had the screen blocked so fuel could not enter the float chamber or was the screen interfering with the needle valve's plunger, keeping it from dropping with the float ?
Deleted member 8987
You take spray carb cleaner, clean the screens, and re-install, or whatever garbage is coming in from your fuel line will rapidly make the carbs in need of another going through.
Dono
Howdy Poolboy,
I'd say the screen plugged fuel flow, it does not move, only a pin inside the part. Dono
Dono
Hi TOC,
I did clean it and may reinstall, but I wanted to prove the fuel stoppage idea first. Thanks, Don
KVH General TR TR4A Engine Won't Start Triumph 34
TulsaFred TR6 TR 6 engine won't start Triumph 4
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
R MGB-GT MGB GT won't start after engine is warmed up MG 3
R TR2/3/3A TR-3 engine won't start after rebuild Triumph 8
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
J Engine won't turn off TVR 3
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
F 77' Midget engine won't stay on---- MG 7
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
