Rob Glasgow
I created a similar situation years ago when I over-oiled the OEM air filters after cleaning them. I somehow got enough oil on the wire mesh to restrict airflow and cause an over rich situation.
If you're getting that much oil in your rear air filter you should check your rocker shaft for wear. If it's spouting oil you're probably losing a PSI or two of oil pressure.
I just measured it....I ended up at 0.67 ....the depth may vary from car to car because it's also dependend of needles and air filter used...
