Is it possible to change the engine mounts with the engine in the car r do you have to fit them before you lower the engine into psition?
The TR3B I am working needs the engine munts replaced. I can not get the starting handle to engage and the owner said that he use to use the starting handle. If I can not get the mounts out I may just add some of the spacers. There are no spacers at the moment and a previous mechanic may have left them out.
David
David
Hi Guest!
