MikeMcD said:A motor head buddy of mine is determined to "upgrade" the engine in my '70 Spitfire. He thinks a rotary would be great. Anyone have any experience with putting newer engines in these cars, rotary or otherwise?
MGTF1250Dave said:Aloha Mike,
I think if you intend to drive the car in situations where you can run it in the 4000 RPM and high for some time you might not have the trouble my wife did.
Andrew Mace said:I'm definitely with Mickey on this: stay with what you've got. Assuming it's an original "FE" series 1296, it's one of the nicest of the small Triumph engines made. Also assuming it still has the single Stromberg as stock, you can do a lot with little more than a pair of SU carburetors and the "non-emissions" camshaft. That will get you from just over 60 hp to about 70-75 horsepower. Then spend a little time following some of the many tips folks like Kas Kastner have provided over the years...and have fun getting up into the 80-90hp range, still with a nicely balanced car that won't need much more than top-quality brake linings and good rubber on the ground!
shining_armor said:Go back a little further. The 60 degree Ford V6 2.6 liters in 1972 and 1973, 2.8 liters after that. No ECM, no computer, compact, light weight, bolts up to a Ford Type 9 5-speed. Performance parts still available. You can do this without making a monstrosity. Double the displacement. More than double the horsepower. Any mod to the hood can be very subtle.
Ernie
1970 Spitfire MK III
2.6 Ford V6, 5-speed
Twosheds said:Grassroots Motorsports did a rotary Spit. Their advice to someone considering the swap: "Don't!"
Don Elliott said:Joe Curry has a hot engine swap in his Spitfire.
https://www.fot-racing.com/spit/caption/spitcurry.htm
