Hi Rob,
Here's a marked up photo with some notes below. For a '67 BJ8, some of these won't be needed or are incorrect. This is one problem with a 'kit' of labels. Some are not applicable and some are the wrong graphic or type of label.
A - Tudor Bottle Label - Not sure if a label is original treatment or if they were silk screened?
B - Wire Harness Label - correct. This wraps around the main harness just to the right of the voltage regulator (as viewed from the front of car). On my car it was placed under the harness P clip and barely visible.
C - Rear valve cover plate. This is the earlier brass "valve clearance setting" plate which is riveted on. The brass plate was used until the middle of BJ8 production and then they changed to a silver/black plate (still riveted on). Then the changed to a silver foil label. Those valve covers don't have rivet holes.
D - Interior heater box label. These need correct numbers stamped. Unfortunately the repo labels are not an exact copy graphically.
E - Lucas Coil label
F - Cooper Air Cleaner labels. These were originally 'water slide decals' but most suppliers have them as stick-on labels.
G - Triplex label. Originally the glass had markings applied during the manufacture. Not sure if this is a stick-on label but if so, would not be close to looking original
H - Not sure if this is for the OD relay, Voltage Regulator or what. Let us know what it says.
I - Brake reservoir label for the early cars. This should be a water slide decal but obviously isn't used for your car. You should have white 12 pt Helvetica letters saying CLUTCH and BRAKE along the lower portion that correspond to the brake line placement
J - Car Number plate for firewall. This needs to be stamped with the car number (
www.clarkspares.com can do this if provided with car registration documents)
K - Front valve cover plate. Also the earlier type riveted plate used into BJ8 production. Then switched to silver foil label with valve cover having no rivet holes.
