Engine color and paint?
MadRiver
Bronze
I know this was discussed recently, but I can't find the threat -- engine color was originally flat black for the 250 and 6, yes? Thanks!
michalotti_tr
To the best of my knowledge, all Triumph engines were originally a semi-gloss black. The only exception I am aware of is SAH (later TriumphTune) would paint their Stage I - III a battleship grey.
Geo Hahn
TR3s & 4s also had a model designation hand-painted on the side of the block (below the header, above the starter) in orange paint in about 1.5" letters... e.g. "T R 4" with the '4' being below the 'T' & 'R'. Did 250s & 6s have such markings? Figured if you care enough to ask what finish is correct you might want to check on this detail.
Alan_Myers
[ QUOTE ]
[/ QUOTE ]
Hi Geo,
Really! I've never seen that on TR3/4 (nor any of the 6-cyl. cars). Have you got a photo or is it illustrated in any of the usual "originality" books?
Geo Hahn
Here's the markings on block of my '64 TR4. Only somewhat legible, but at least enough so to get the idea.
I actually thought this might be the work of some machine shop who needed to keep track of which engine this was, except I was pretty sure the engine had never been out of the car. Then I saw a pic somewhere of the original marks and (as they say) 'the penny dropped'.
Almost looks like it may have been put on by someone dipping his finger in the paint pot.
ichthos
I had asked the same questions a couple of weeks ago. My car sat for over 25 years ins storage, so most of the paint colors in the engine compartment are clearly unmolested. The only color not clear to me is the engine itself. Eventhough most feedback said it was painted semigloss black, most of the individual parts within the engine compartment are gloss black (stayrods, washer bottle bracket, steering column,brake booster...). It doesn't make sense to me that they would paint the engine color semigloss and the rest of the components gloss black. I looked at older pictures of TR6's, and it looks like it is possible it could be gloss or semi. I am probably making a bigger deal out of it than I should, but I figure if I am going to go to the trouble of painting the parts (using powdercoating when possible), I would like to paint it the original color. I won't have the chance to go to a British car show until July, so I will be quizzing people there also.
Kevin
Mickey Richaud
Yep - the TR3 that I had also had the red-orange TR3 in large characters on the side of the block. Somewhere in Bill Piggot's book, Original TR3, he explains that the engines were used for a multitude of cars back then, and this was the way they were sorted at the factory.
Mickey
Alan_Myers
Interesting! Looks kinda like finger painting or maybe they borrowed the wife's lipstick. (Or, perhaps it's a cave painting!)
At any rate, I don't think they marked any of the 6 cylinder engines that way.
Alan_Myers
[ QUOTE ]
The only color not clear to me is the engine itself. Even though most feedback said it was painted semigloss black, most of the individual parts within the engine compartment are gloss black (stayrods, washer bottle bracket, steering column,brake booster...). It doesn't make sense to me that they would paint the engine color semigloss and the rest of the components gloss black. I looked at older pictures of TR6's, and it looks like it is possible it could be gloss or semi....
Kevin
[/ QUOTE ]
Hi Kevin,
I'm pretty sure you can find a rattle can of semi-gloss that will give you the most original appearance on all those parts. There *is* some variance in gloss, from brand to brand.
Actually, I wouldn't have been surprised at all to find different sheens on various parts under the hood, when the car was brand new and fresh from the factory. The engines were being built in one plant, the chassis in another and the bodies in still another. Individual parts were being made elsewhere, both by Triumph and other outsourced manufacturers. It all came together in a final assembly area, where the car was completed. So, I think it's very possible, even likely, black was not consistent from part to part.
Take Lucas wiper motors, for example. Some were painted in part with wrinkle finish black, others had a dark grey "hammer" finish paint. Either is correct on some TR models, there was so much variation right from the original manufacturer.
Semi-gloss is usually around 80% gloss, which compares to 90% for gloss and even 95% for high gloss. Low gloss might be 70%, while flat finish might be close to 50%. So called "underhood" black and chassis paints I've seen seem to be in the 70-80% range. But, again, it varies. At least we can say with certainty that it wasn't flat black originally!
Eastwood Co. probably has the widest selection of black paints, but they are pretty pricey. I'd suggest going to several local hardware and auto parts stores and picking up a few different brands of engine paint, then test spray some parts to see which you like best.
Besides "semi-gloss" engine paint, you might also want to check out "radiator paint". It is also semi-gloss, but has a greater amount of pigmentation, so that a relatively light coating can be used aand will allow for best heat transfer from a radiator. IMHO, it would be good for the engine for the same reasons, providing you can get it in a sheen that you like.
BTW, I've occasionally deliberately used a low gloss or even flat black and then top-coated it lightly with semi-gloss clear, to get the best possible sheen match to other parts. After the clear dries enough to compare, a second or even third light coat of clear can be used to "adjust" the glossiness of the part.
trfourtune
hey,
my engine has those markings- tr4 - hmmmmm- i thought it might be from a shop (rebuild) but my car sat for 30 yrs after some damage and parked before i bought it. maybe this is original.
rob
trfourtune
i've seen blue on some blocks and heads on tr4's. was that original?
rob
Alan_Myers
[ QUOTE ]
rob
[/ QUOTE ]
Hi Rob,
On TR4 I believe they were all black originally. In fact, as fas as I know, all Triumph engines seemed to be black.
The main oddity of paint color among Triumph, I'm aware of, is TR3 frames. Apparently some were just painted with whatever color happened to be in the paint gun at the time.
apbos
"In fact, as fas as I know, all Triumph engines seemed to be black" I'll throw in a curve ball. In my research on my car I've found out that in the 1949 roadster green (similar to buick green)was used as an engine color. Another Triumph /ubbthreads/images/graemlins/england.gifpost-war oddity.
Paul
Alan_Myers
Good point, Paul.
I should have limited my statement to TRs and a few other models that were widely sold in the U.S. from around the mid-1950s through mid-1970s... i.e., what I'm most familiar with.
Yours is a great looking car, by the way. I always really liked the roadsters' styling and features. The "rumble seat" is especially cool!
apbos
Allen
I bow to the master /ubbthreads/images/graemlins/yesnod.gif. But, I cannot claim ownership of the vehicles in my post or my avatar. My avatar picture is what I believe to be the perfect example of a Lumina Green TR. In 1949 the TRA was available in for colors, Black, Lumina Green, Lumina Champange and Lumina Grey. My car came from Coventry; Lumina Green. You can see pictures of my restoration to date at https://pg.photos.yahoo.com/ph/paulbos@sb.../ph//my_photos. 5 months into a 2 year restoration
Paul
Brosky
Everything that I could find indicated gloss black and after I cleaned portions of my block, the original was gloss black. This attachment is mine so far in the latest engine compartment refinish project.
Marvin Gruber BJ8 engine paint color. Austin Healey 25
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
M Poor Dupli-Color engine enamel paint results Triumph 13
lbc_newbie Engine paint color....conundrum Spridgets 35
N 1964 sprite engine paint color Spridgets 3
S Mini engine paint color and pics needed British Motor Corp 9
P General TR What color is original for engine parts? Triumph 7
T Austin Healey 100 engine color Austin Healey 10
maxwedge5281 engine compartment color Austin Healey 2
C Longbridge engine color Austin Healey 16
Marvin Gruber New engine color thread BJ8 Austin Healey 33
Kirk_Fisher TR4/4A Engine block color Triumph 6
NutmegCT General TR engine bay color Triumph 9
M Correct Engine Color Triumph 4
bighealeysource Engine ID tag color on BN2 Austin Healey 3
B Spitfire 1980 Spitfire engine block color Triumph 14
E TR2/3/3A 1961 TR3A Engine Color? Triumph 7
1 Original engine color Austin Healey 14
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
GBRandy TR2/3/3A TR3 Engine Bay Color Triumph 5
Stewart engine color MG 4
vping Engine Color options MG 68
B Engine Color MG 25
2wrench Stock engine color or what? Triumph 28
TR4 TR Engine Bay Color ? Triumph 21
NutmegCT engine bay color Triumph 23
M XK 140 engine color Jaguar 2
LeeMcKee Engine swap and frame color? Triumph 6
LeeMcKee MGB Engine Color MGB MG 2
W BE Engine What's Painted? What Color? Spridgets 29
budk1953 Engine color - REVISED Spridgets 18
I TR6 Engine and engine bay color, TR6? Triumph 4
HAN8L1965 Engine color question? Spridgets 1
Tullamore TR6 71 TR6 Engine Color Triumph 5
S TR2/3/3A Engine bay color different on tr3 Triumph 4
A Engine Color for 1976 Midget Spridgets 7
S Sprite Engine Color Spridgets 10
S Engine color Austin Healey 3
Cain Engine Color Triumph 8
C Healey engine color Austin Healey 4
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
