I'm ready to take my block to the machine shop for mostly ordinary work. The question of deck flatness will come up, I expect. Is it customary to shave the top of the block to flatten the deck? If so, how do you adjust the cylinder protrusion to achieve the rather narrow spec of 3-5 mils? The shop manual says to use figure-8 gaskets of some appropriate thickness, but I see two problems with this: (1) they don't seem to be very easily available, and (2) if you shave the block, you might be left with too much protrusion, even with a thin gasket.
So, what is done about this? If necessary, is is OK to shave the tops of the cylinders, for example?
Hi Guest!
