saltshaker
My emergency brake lever is stuck in the up position. The button will not work. what can i do to get it to release? Will it require removing the passenger seat?
jlaird said:...A rod runs from that button to a paw that pivets on a ratchet toothed afair and you can see it from the tunnel side of the brake lever. On down at the bottom is nothing more than a shaft that runs into the tunnel with an arm on the end that pulls and releases the cable...
saltshaker said:Thanks for all the help and suggestions.
Only one question.... what is PB Blaster and where do i get it?
PLUS --- sorry for posting question in wrong place.
Dan
DrEntropy said:It even fixes leaky toilet flush valves... says so right onna can. :smirk:
