Emergency advice needed
Morris
I just discovered that me rear left brake is dragging. Should I ease her home, or get a tow?
Answer needed before I finish my margarita!
Assuming drum, can you release it a bit by backing off the adjuster? Is the E-brake cable nice and loose?
If the e-brake cable is rusty, and hung up a bit, moving the housing around a bunch will often release the tension.
Also, try backing up and hitting the foot brake.
Shoe movement will sometimes kick a sticking e-brake off.
I had a car that was like that once.
At the time, finding a one-piece rear e-brake cable for a 2WD 1949 Willys Wagon was not an option.
That's cause you didn't know Raymond Cusimano !!!!! ( or he was dead already.)
Morris, beating on the back plate w/ a hammer works too fer hung up e brakes and such.
This was 30+ years ago.
4WD parts all over, but not 2WD.
Finally put a Mustang 8" in the back with the cables it came with and other than some cable slack adjusters, works fine.
Ebrake is perfect. I think it's a busted return spring.
I don't think I can get to the adjuster in the busy restaurant parking lot.
Tow it?
Is was good and alive then and had ANYTHING hard to find IN STOCK. Probably had a few new and used. He had several whole wagons around and a really nice fully restored Jeepster for his wife. He was a great guy, you would have liked him. He passed away in '88.
He once ran a guy off for asking him if he had points and plugs for a Blazer.
"Get the hlll out of here!!! Go to NAPA !!!! We only have hard to find stuff !!!!"
He was quite a charater.
Tow it?
Sounds like it, if you think it's doing damage to drive it.
Plus - Margharita's? Yeah - tow it. :wink:
Unless you want to jack it up, pull the wheel and drum right there in the parking lot, then hike to someplace that might have a spring, if you're concerned, tow it.
Oh, and since you won't be driving, have another couple of Margaritas while waiting for the truck.
I would have one more and then drive that sucker :wink:
yeah is sounds like a stuck E-brake. Let it cool good and it might free up. Me, I would pull it there in the parking lot. You still got to fix it there or at home. Still, I am not normal, so do what you think best
should a towed it :cryin:
