Electronic Clutch [Deleted]
Status
Not open for further replies.
Administrator
Boss
Basil submitted a new resource:
Electronic Clutch - An electronic clutch device to allow people with limited leg strength to drive manual cars
In a thread about replacing the gearbox in a Triumph TR4A, one of our members @RGK posted a link to an outfit that sells an "Electronic Clutch." It's a clever device that, once installed, allows drivers with limited or no leg strength to simply press a button on the shifter knob in order to shift a manual gearbox. Click the download button above to download a flyer, or visit their website...
Read more about this resource...
NutmegCT
Here's the "hand operated clutch (and brake)" system on FDR's Ford Phaeton:
Also had accelerator on the steering column.
(And an automatic cigarette dispenser, which lit the cigarette so he could light up using only one hand.)
Car is on display at the Hyde Park estate.
LarryK
I thought electronic clutch devices were called automatics.:rolleyes:
NutmegCT
NutmegCT
Basil - AutoStick was quite a device. City driving in Low range (1-2), country driving in High range (2-3). Automatic vacuum clutch.
Very cool!
Administrator
Boss
Very cool!
I used to drive Mom's car all the time. It was a 68 Bug Convertible. It had a stick shifter but no clutch pedal. It was a fun little car to drive, but sure wasn't very fast.
PAUL161
I had a 72 superbug with that shifter, never had a problem with it, you could also take off without shifting in high gear, but it was very sluggish, I never used it. Loved that bug though, great for getting around the city, and believe it or not, it was pretty comfortable to ride in with its radial tires.(y):encouragement:
Bayless
My (or I should say herself's) '74 Super Beetle is also not very fast and it has the standard 4-speed with clutch. But still it's fun and gets pretty good mileage.
Administrator
Boss
This resource has been removed and is no longer available.
Status
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
O Sprite Petronix Electronic Ignition Spridgets 10
S General Tech Electronic store for quality connectors. Triumph 9
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
B Crane Cams Electronic Ingnition Austin Healey 9
S Wiring connections for electronic ignition BJ8? Austin Healey 3
T MGB Vacuum advance and Electronic ignition conversion MG 5
rjc157 bn7 electronic choke Austin Healey 0
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
S TR2/3/3A Tr3/4 electronic distributor Triumph 2
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
T TR2/3/3A electronic distributor problem Triumph 3
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
F Swapping out original 1098 distributor to electronic Spridgets 13
L Electronic ignition? British Motor Corp 4
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
Keith_M SU Electronic Fuel Pump Spridgets 3
DanLewis Electronic tachometer for Bugeye Spridgets 18
R Electronic Ignition Distributor Spridgets 14
JPSmit Electronic Rust Inhibitors: works? - or snake oil? Restoration & Tools 8
D Electronic Ignition for 25D distributors Spridgets 15
D Timing with an electronic distributor? Triumph 14
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
bighealeysource LED bulbs and electronic flasher module issues Austin Healey 26
M Fuel Flow problem with new Electronic SU Pump Austin Healey 2
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
PATR8 Wedge More TR 8 electronic questions Triumph 2
T Electronic Ignition Issue Austin Healey 6
wkilleffer Anyone familiar with GM Electronic Climate Control Other Cars 11
A Pertronics vs Electronic Distributor Triumph 23
D Installing Electronic Distributor Austin Healey 8
Tim_Creger need help with electronic distributor MG 7
drooartz Cheap electronic tach for bugeye? Spridgets 9
B What is best electronic ignition setup MG 19
T Electronic Ignition MG 15
