Rut
I've installed the new wiring harness in my Bugeye and followed the Advance diagram. I've not connected the rear harness or headlights and I'm using a 5 amp fuse between the + post and the brown wire. The dash is connected and lights work as they should, but when I turn the key to the on position I blow the 5 amp fuse. This is when the regular fuse is in place between A3-A4. When that fuse is removed and placed in the A2-B position the fuse doesn't blow. Did I say that I'm really horrible when it comes to Electrickery? I understand the concept, but it's really got me buffaloed and after 2 days with a meter I'm no further along than when I started. The heater blower and switch, wiper motor and switch both work and test out ok. Help!
Thanks, Rut
Thanks, Rut
