General Tech Electrical terminals
lram59
Are there any venders left who sell quality, OEM style electrical connectors? All I can find is cheap, overseas junk and I would like to replace all of the underbonnet terminals. 20211119_113748.jpg
Larry
bammons
I saw them recently and it may have been a British firm that had them. I recently bought a new wiring harness and I think I saw them when looking for it. I checked TRF and could not find them although that doesn't mean they don't have them. I may need some soon. Bruce
Stevenry
I got a good assortment of bullet connectors and an excellent crimper from a motorcycle parts distributor. I don’t recall who of the top of my head, but I’ll look for a receipt tomorrow. I also had no luck with the usual triumph parts sources.
Steve
Stevenry
It was the Bonneville shop. Lucas electrical kit with connectors. The crimper is expensive, but does a great job. The wont come loose.
Steve
jimmyr
One process that I have always done on connectors is to carefully solder the terminals after crimping. Some items as bullet or splices cannot be soldered, but ring terminals and blade terminals lend easily to being soldered.
poolboy
Don't know specifically what you want but you might find it on these 4 pages.
I've used their bullets and insulated connectors
Sarastro
I used Molex connectors when I restored my TR4A. Those are the white nylon connectors often used in computers for power-supply connections. You can get them on eBay or various electronic suppliers, like Mouser and Digikey. They are very reliable, but not weatherproof, so you probably don't want to use them where they could get wet.
I have also noticed a number of OEM-style connectors available from Amazon. I didn't use them, but they seemed like a good option--especially since many are sealed.
For the spade connections, I used new connectors, soldered them, and insulated them with shrink-wrap tubing.
Here's the story: > Body electrics <
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
S TR4/4A Electrical wiring tips Triumph 2
K TR2/3/3A More electrical....the Starter? Triumph 5
B TR2/3/3A Electrical Problem Triumph 13
T TR2/3/3A electrical oddity Triumph 7
L Should I do it?? [electrical conversion] Austin Healey 24
SherpaPilot TR6 Electrical Question Triumph 7
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
