When we were examining the clutch pedal, a wire must have come loose because the following are not functional: gas gauge, water temperature, wipers. heater and direction signals. All four fuses checked out ok. The only thing amiss was the flasher unit which was out of its holder. I did see that at least one other poster had the same problem but in his case, it was the fuse box. Can anyone give me a hint what to look for?
Hi Guest!
