Electrical Help.
Crisis
I was hoping someone out there could help clear up some confusion I'm experiencing with my 73 TR6?
It concerns the starter circuit. Turning the key would not crank the starter. Upon inspection I found two frayed wires going to the starter. 1-heavy w/r, 1-lighter w/y. I pulled back the tape and re-taped the individual wires. Starter will now crank. My question is; what is that clip/connector attached to the red battery cable? Does it provide a connection to the battery cable? I've got 2 heavy brown, and 1 smaller brown wire going into the clip, then coming out the other end and going back into the firewall. One of the wires coming out of the clip is suspect and I was hoping someone could shed some light on this part. Thanks.
TR3driver
Great Pumpkin - R.I.P
Yes, exactly. That's where the entire car (except the starter) ties into the battery.
C
Crisis
Thanks Randall. I guess this may explain a number of electrical problems I've been having?
Do you know of a link where I could find out what gauge all the TR6 wiring would/should be?
Reid
DNK
As gig as you want. Check out British wiring. I also have that info somewhere I'll try to dig it up.
G
Reid
Reid, the absolute handiest thing you can have for your 73 TR6 electricals is to buy Dan Masters' book on TR6 electrical problems and solutions. Included in the book is a complete, accurate wiring diagram for your specific year (and all others). The book is available from Moss Motors and worth every penny.
TR3driver
Certainly possible, I've seen several cars with problems in this area. Pop the cover off and look for any signs of overheating.
Sorry, I don't. But this chart should be helpful in figuring out what it should be (as opposed to what it was) :
https://www.powerstream.com/Wire_Size.htm
Use the "amps for chassis wiring" column.
Of, if you are planning a major rewire project, you might consider this :
https://www.advanceautowire.com/harness.htm
TR3driver
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
JIC anyone doesn't know, the same Dan Masters founded Advance Auto Wire; just to sell upgraded LBC electrical systems. Dan is a retired power plant EE, so he knows quality wiring; and owns a modified TR6 so he uses what he sells. His son does most of the running of AAW, but Dan still does the designs.
mrv8q
Or available from Dan, directly for $30Us, and $5 shipping, ISTR.....
DNK
Tom- The hand book is not available on his site.
TR3driver
Last time I talked to Dan, he said he was trying to get away from work and spend more time with his grandson (and Triumph). He used to print and bind those books himself; but I believe he sold out the last run and has no plans to do it again. TRF produces them now, P/N RFP605, currently on sale for $39.95.
6 Electrical Help Please Spridgets 7
E GT6 Help electrical guru needed Triumph 4
N Electrical Issues Need Help Austin Healey 8
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
H need troubleshooting help with 100-6 fuel?electrical? Austin Healey 9
K Need some help, electrical issue Austin Healey 45
I TR6 Need some electrical help please. Triumph 4
I TR6 Electrical issues - please help. Triumph 5
bash TR6 TR6 electrical help Triumph 11
6 Electrical help please Spridgets 21
I Horn electrical hook up help please Spridgets 15
I Bugeye lighting/electrical help Spridgets 17
DNK Help from electrical Gurus Triumph 4
T 67 Sprite Electrical Problems.... HELP Spridgets 7
T 67 Sprite Electrical Problems.... HELP Austin Healey 1
kyreb1862 Electrical System Problem Need Help ASAP MG 7
Jim_Gruber Fuel or Electrical - Help Needed Spridgets 1
Jim_Gruber Help Needed - Fuel or Electrical Spridgets 16
Lin Electrical Issue - Need help Austin Healey 8
G Spitfire Help with Spitfire electrical problem Triumph 13
1 Help on a bad problem, electrical, fuel? MG 12
curtis Electrical help please Austin Healey 3
M 97 XJR Electrical problems...HELP! Jaguar 10
1 Electrical Help PLEASE!! MG 8
S HELP! with jag electrical Jaguar 2
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
