Electric fuel pump wiring
rossco
Please check my work. 59 Bugeye, positive ground. SU Pump is bolted to frame. Is that my ground? Wire goes from screw terminal to ignition switch white terminal. Is that it or do I need something to the control box and/or coil?
That should do it!
Can I just run my fuel pump hot wire to the white wire terminal at the fuse block? It's easier than crawling up under the dash!
