TRnorwegian
I've only driven forty miles since aquiring the car, and since these transmissions is sweaty, I wonder how much oil is hidden inside. How do I check and refill?
While you are at it, install a magnetic drain plug.
71tr said:Don't you just fill the tranny until gear oil begins to seep out the fill hole?
On mine, I rebuilt the original trans cover (with a dipstick) with TR6 rods & forks to use on the TR6 transmission I installed. Now I can just pop the rubber body plug out, check the dipstick, and pour from the bottle.Don Elliott said:On a TR3A that I restored,
