TR4/4A Early TR4 - Timing Cover Oil Seal
T
TRDejaVu
When I had my TR4 and then TR5 thirty odd years ago as daily drivers if something needed replacing I went to the BL dealer and got parts that looked the same. Nowdays parts are remanufactured or updated and don't always look like the part being replaced. This is the situation with my timing cover oil seal.
The old seal innards had aged and disintegrated when I took the cover off. I think I know which way round the replacement should go, but I am (obviously) not 100% sure. I have attached 2 pics (I hope). I would appreciate opinions on #1 or #2.
T
TRDejaVu
Thanks Wayne, that's what I was thinking, but there is an inner lip that made me unsure. My original seal was within a metal "frame" closed at both ends.
PeterK
just remember, the lip always faces the fliud and you'll be correct
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
Zitch TR4/4A Early 63 TR4 [CT16438L] Dash refresh Triumph 3
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
T TR4/4A TR4 early dash Triumph 7
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
J TR4/4A TR4A radiator install into a early TR4 ??? Triumph 14
Marvin Gruber TR4/4A Early TR4 gauge glass Triumph 13
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
HerronScott TR4/4A Early TR4 gauges on Phoenix Craigslist Triumph 2
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
T TR4/4A Early TR4 Steering Triumph 2
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
T TR4/4A Early TR4 Hood Stick Covers Triumph 14
SCguy TR4/4A Early TR4 Seat Tracks Triumph 2
T TR4/4A Early TR4 Clutch Triumph 7
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
milemarker60 TR4/4A Need some early TR4 Windshield Frame Pics -Please Triumph 0
T TR4/4A Early TR4 - Windshield Trim Covering Triumph 10
T TR4/4A Early TR4 Choke Cable Routing Triumph 6
SCguy TR4/4A EARLY TR4 SWITCH PLINTH Triumph 3
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
T TR4/4A Early TR4 - Crank Pulley Woodruff Key Triumph 7
T TR4/4A Early TR4 - Front Brakes Triumph 3
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
