dklawson
Let me start by saying that this topic is about the early 150CD carbs on my '67 GT6. These are not the same carbs as used on the later emission controlled cars.
I found that the float in the front carb of my GT6's pair of 150CD carbs was a sinker. Fortunately I had a spare carb to take a working float from. However, I want to keep the spare carb ready and functional so I want a replacement float for it.
The later carbs use a different style float as seen to the left in the JPG below. I have spoken to Joe Curto and he says the early style float is NLA and his suggestion is to seek other used floats as spares. I have tried dry-fitting the later float to my early carbs and it looks like it "might" work if I:
However, with new floats costing $20 I'd like to know if anyone else out there has tried to adapt these later floats to early carbs (any TR4 guys out there?). If you did try what I am suggesting, were you able to still use the stock float height setting as listed in the manuals or did you have to increase or decrease the specified height measurement?
Thanks for any advice you can offer.
- make a new, slightly longer pivot pin,
- cut off one of the later floats float valve actuating arms,
- make a spacer to push the later float slightly to one side in the bowl.
