Dynamo numbers
6TTR3A
<span style="font-size: 12pt"><span style="font-weight: bold"><span style="color: #006600">I'm trying to figure out what the amp output is on my TR3A generator. The numbers stamped on the case don't offer a clue (to me ) Any interpreters out there??</span></span></span>
<span style="font-size: 14pt"><span style="color: #003300">I enhanced them for clarity.
Thanks in advance, Frank</span></span>
6TTR3A
6TTR3A
Thanks, John, Those are the numbers for a C-39 model (Early TR2) This one is a
C-40 model. (Hopefully a higher amp rating !!)
Frank
MGTF1250Dave
Aloha Frank,
I got a table awhile back from Randall and it shows the C40/1 output as a 20 Amps + or - 1 Amp with a 4.5 inch fan and 22 Amps + or - 1 Amp with a 5" fan. I could seem to add the whole table.
Here is another table:
DYNAMO
Make/type Lucas C40
Maximum output 22 amps
Cut-in speed 1450 rpm at 13.5 volts
Control box Lucas RB 106/2
Regulating voltage 12.7 - 13.3 volts
TR3driver
Great Pumpkin - R.I.P
Sounds right, though I'm away from my references at the moment.
Don't forget though, that the control box is what really controls the current. The 22 amp control box is different than the 19.
sp53
I would somewhat be concerned with the numbers because the field coil cases can be interchanged, the same thing with the starters. The pre60K case will interchange with the Post 60k case at least that is what the Lucas manual suggested at one of my favorite local rebuild shops.
HerronScott
I'm pretty sure the 70 indicates the generator was built in 1970. The 50 preceding it may indicate that it was built in the 50th week of 1970 as well but it has been quite a while since I checked out my generators.
Scott
woolfman C39 vs C40 Dynamo rebuild/parts Spridgets 0
Walter74 Dynamo to alternator Austin Healey 2
S Wanted Wanted - C39 Dynamo [22258D] Triumph Classifieds 1
M Dynamo to "Dynamator" Conversion Austin Healey 2
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
SASSAMON TR2/3/3A WTB Pulley and Fan for TRactor Dynamo Triumph 3
J Dynamo and Stereo Other British Cars 1
F Generator/dynamo bushing replacement Spridgets 2
R TR2/3/3A C40 dynamo terminal identification Triumph 4
angelfj1 C39 Lucas Dynamo rebuild - Moss armature does not fit Triumph 9
O Dynamo with a mind of its own ! Austin Healey 8
angelfj1 TR2/3/3A TR3A - Dynamo Fan is loose! Triumph 3
Jeepster Dynamo to alternator conversion Austin Healey 10
ArcticOne GT6 WANTED - LUCAS C40L DYNAMO / GENERATOR [1968 GT6] Triumph 4
P Generator/Dynamo Problems MG 3
Geo Hahn TR2/3/3A TR3/4 Dynamo Bolt Triumph 10
J Burning Dynamo Austin Healey 2
MGTF1250Dave Lucas 12V Dynamo / Generator Specifications Triumph 2
Indnrdr Did I cook the control box and the dynamo? Austin Healey 2
K TR2/3/3A TR3..Red light On...Dynamo Connector Triumph 5
tj_tr3_tr6 TR2/3/3A 59 TR3A dynamo problem Triumph 12
Z MGB MGB1964 what i have?Dynamo,alternator,generator. MG 8
pan Generator [Dynamo] bearings Austin Healey 3
D Dynamo - distance between mounting faces Austin Healey 5
C austin seven dynamo brushes Other British Cars 7
A BJ8 / C42 dynamo bearing specification Austin Healey 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
K 100/6 Stamped Numbers Austin Healey 6
Z For Sale 1955 MG TD Original car, numbers matching, restored to immaculate condition MG Classifieds 10
steveg Searching Burlen's website for part numbers Austin Healey 0
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
TomMull Numbers re Chassis project Lotus 4
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
S Gearbox and axle serial numbers Austin Healey 7
Got_All_4 TR6 Do these numbers on the head mean anything? Triumph 6
BN6 Austin Healey Ruddspeed Engine Serial Numbers Austin Healey 4
simon1966 Numbers stamped into a BN1 block? Austin Healey 5
TomMull Matching Numbers? Other Cars 5
J Engine numbers for an Austin Healey 67? Austin Healey 3
J Engine numbers for an Austin Healey 67? Austin Healey 2
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
M TR4/4A TR4 A Comission Numbers? Triumph 16
T TR5/TR250 TR-250 Production Numbers Triumph 1
J TR4/4A TR4 Series Vehicle numbers Triumph 1
2 TR2/3/3A compression numbers Triumph 1
trotti Engine numbers - any info you can provide? Austin Healey 2
