Dumb carb question
Are the spacers necessary on the HD8 / Bj8 carbs? It would be a whole lot easier to remove the air filters with them. Perhaps a thinner version?
Madflyer
To say necessary leads to why they are there and would be your call to leave them off. They reduce heat transfer as not to boil fuel in float bowl one. Two Air fuel mixing takes time as not to flood cyl, That being said even mixture flow into manifold race cars port and polish same, cylinder valves have seats with three cut for more rounded fuel entry and even spread for better burn that leads to more power per firing. For the few times air filters are removed I would say keep them or a fire EX close. I would leave this open for more Threads Madflyer
steveg
The factory thought them necessary. But they didn't live in the mountains and have to run ethanol gas. So maybe the situation has changed.
Jags used a thinner one - around 3/16" - you can get them from Joe Curto or Moss.
Keoke
Very interesting replies:
However:
I been in the mountains , valleys N snow in Colorado but nevah had any trouble from them fellas so I just let them alone.
tahoe healey
My problem is not getting them off (well, yes, that is a problem). The problem is getting the Uni-Syn seated on the carb so I can see the float height.
tahoe healey
That is what I usually use but I figured I'd do a more complete adjustment as I am going on Dave Nock's famous Fall Colors/Passes tour nest week. Some passes are over 10,000 feet from a start at sea level. Then next May many of us are headed your way for Conclave in Big Bear, CA. That will be another a couple of thousand miles.
AUSMHLY
Relating to spacers, what is the correct material for the heat shield to insulating block and heat shield to carburetor.
Moss lists 4 gaskets to use, all same part number, no description of the material.
I have a collection of an aluminum and an orange-ish hard gasket. I have another two that are thinner and more flexible, one is pinkish says SU, the other is solid gray.
John Turney
The grey ones are what Moss shows on their website. They imply that the order is manifold, phenolic spacer, gasket, heat shield, gasket, carburetor. The gaskets are paper.
AUSMHLY
Thanks John.
The paper gaskets being correct, noticed both have the same shape. The aluminum and orange ones have a different shape.
What would the aluminum and orange-ish spacers be used for?
Steve, I see an imprint on your HD8 phenolic spacer that looks like there was an aluminum gasket spacer, like the one in my photo.
Is there a gasket between the inlet manifold and the phenolic spacer? (Moss doesn't show one.) Should it an aluminum spacer?
Keoke
IMO the wire pointers are best - they're like a built-in uni-syn without having to remove the air cleaners.
Yeah Steve:
That's the best way to go for that test
steveg
Thanks John.
Steve, I see an imprint on your HD8 phenolic spacer that represent the same as the aluminum gasket spacers in my photos.
Is there suppose to be a gasket between the inlet manifold and the phenolic spacer? Is it an aluminum spacer?
All I ever used are the gray cardboard ones from Moss:
I'm using three of these on each carb on my DMD manifold. Also shown is the thin Jag spacer. The stock Healey spacers made my front carb dome extend under the fender so I couldn't remove it.
Guessing your aluminum ones went between the manifold and heat shield.
I'm just guessing, but you might not get a good seal between the aluminium manifold and the (hard) phenolic/bakelite spacer without a gasket. I like to use the metal-faced gasket against a hot surface; e.g. the manifold.
steveg
Anderson Moment, p. 157, shows the heat shield to be outboard of the phenolic spacers. Can't tell, but assume there's a gasket between the manifold and spacer.
John Turney
On my car, which is guaranteed to not be stock, but has an original BJ8 intake manifold, there is a paper gasket between the manifold and spacer, in addition to the ones on either side of the heat shield.
gonzo
Phenolic spacers yes, but my BJ7 appears to be equipped with a series of 4 or 5, 1/16 - 1/8 inch stacked asbestos spacers. There are two of them, one separating manifold to heat-shield and the other heat-shield to carb. Gaskets I make myself.
tony barnhill Triple-Carb Interchanges [was "Dumb Question"] Austin Healey 2
G Dumb carb question Triumph 15
LAW75 Stories of "I Can't Be THAT Dumb" Austin Healey 37
AngliaGT MGB Dumb Question - What's This Part? MG 3
B TR4/4A Dumb Bumper questions Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
Darwin Spitfire Dumb Question Triumph 2
M MGB trying to change rotors - dumb question MG 7
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
NutmegCT Dumb bolt question Restoration & Tools 7
D TR6 Dumb question Triumph 2
D TR2/3/3A Dumb question Triumph 3
B MGB Dumb emergency brake questions...help requested! MG 5
D Dumb question Triumph 5
60TR3A Dumb Newbie Question Austin Healey 16
wingsandwheels Dumb mistake...nice drive w/ e-brake on Triumph 6
E another dumb electrical question Austin Healey 8
Jim_Newman dumb little electrical question Austin Healey 3
richberman Dumb SU fuel pump question? Austin Healey 9
M Dumb Dumb Question about Drum Brakes [pics] Triumph 10
B At the risk of sounding dumb..... Triumph 4
NutmegCT dumb antifreeze question Restoration & Tools 4
Sarastro Quick dumb transmission question Spridgets 9
Tugboat Dumb Question re: Battery Triumph 15
T TR4/4A 62 TR4, new owner, [dumb ]question about cyl head Triumph 15
Jim_Gruber My Dumb Present Owner moment Spridgets 24
Frankenhealey Dumb de dumb dumb DUMB [Portentious music!] Austin Healey 0
C This might be a dumb question but.... Spridgets 15
tahoe healey Dumb-dumb Austin Healey 10
T Can I powder coat this stuff or will it look dumb? Spridgets 10
T I think I did a dumb thing Spridgets 14
TR6oldtimer TR6 TR6/250 water pumps and a dumb PO [me] Triumph 4
I TR6 A few dumb TR6 brake questions Triumph 9
Pythias Dumb Present Owner Spridgets 20
S Will Basil kick me off for dumb questions...? MG 9
M A Dumb, but Necessary, Question Spridgets 11
Grampy 72 Midget Dumb questions for the day Racing 7
Yngbld14 Dumb Question MG 0
Yngbld14 Dumb Question Spridgets 2
StupidHippie Really dumb diff mount question? Triumph 12
2wrench Dumb question I gotta ask Triumph 2
walshja OK, I did something dumb Spridgets 24
jlaird Dumb question Spridgets 2
E TR6 TR6 Diffy - Dumb ? But Thought I'd Ask Anyway Triumph 4
judow Dumb Question? Jaguar 5
tony barnhill Dumb Late Night Question Spridgets 8
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
G So here's a dumb question Triumph 20
