Dry fitted the HS6 today..
Nunyas
So, I dry fitted the HS6 to my manifold today to get a clear idea on how much modding and fabricating I'm going to have to do to employ this puppy in place of the Zenith-Stromburg.
First mod will be notching the ZS Heatshield bracket, because it prevents the throttle from going full open. The choke idle speed adjustment screw butts up against it when attempting to go full throttle.
Next, I'm gonna have to fab up a throttle cable mount point. The HS-6 I have has all the throttle attach points on the left when looking into the throat. That shouldn't be too difficult, IMO. Some aluminum C-channel stock and JBWeld or rivets ought to do the trick there.
Finally, it appears I'm going to have to source a throttle wheel. The throttle wheel from the ZS won't work because it's too large in diameter. The ZS throttle wheel butts up against/interferes with the choke mechanism and the heatshield brackets.
I didn't take any pictures of the initial fitment, but it's a darn sight less cluttered in that area of the engine bay with the ZS + monstrous air filter contraption removed, and the HS6 hanging off that manifold with its round air filter.
I've started hand polishing the dash pot exterior this past week, and got it up to "cloudy mirror" status on the shiny-o-meter in one evening. I figure I can get it up to high polished chrome shininess with another evening of hand polishing. /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
erm... I've done some digging (not very deep mind you), and I've noticed that I don't see any 'throttle wheels' on any of the 'complete' SU carbs on eBay... like the auctions that come with the carbs + "all linkages" + manifold; no wheel to attach the throttle cable to.
What's the deal, do SU's just link the throttle cable to a lever hanging of the throttle shaft?
YES
Well, that affects me in two ways then. 1) finding a throttle wheel will be like trying to find hen's teeth, and 2) I won't have to find a wheel, and I can just fab up a lever to get the job done /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
End result: no parts sourcing necessary. I only have to do some parts modifications and fabrications to bring my B to salvation! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
That'd be my method as well. Since I no longer have an HS^ lyin' about, what's the diameter of the shaft? I'm wondering if it's the same as the 4's.
ehhhh ... uhmmmm ... "stock" size? heh
I'm not sure. I'll have to rough guestimate it with a tape measure and an eye ball when I get home later. Ain't got a mic for precision measurements.
Set of dividers an' a gradumecated stick in 1/16" divisions? /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
compass and a ruler? /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Yup-yup. It'll give you a fair assessment as the shaft is likely to be some "standard" size: 5/16" (0.3125"). for HS4's.
very well, carry on!
Aye, Sir!
/bcforum/images/%%GRAEMLIN_URL%%/banana.gif/bcforum/images/%%GRAEMLIN_URL%%/banana.gif/bcforum/images/%%GRAEMLIN_URL%%/banana.gif/bcforum/images/%%GRAEMLIN_URL%%/banana.gif/bcforum/images/%%GRAEMLIN_URL%%/banana.gif/bcforum/images/%%GRAEMLIN_URL%%/banana.gif/bcforum/images/%%GRAEMLIN_URL%%/banana.gif/bcforum/images/%%GRAEMLIN_URL%%/banana.gif
Howzat? /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
lol
not yet. I should have the air filter that I ordered either today or tomorrow. I'll take pics of the carb & air filter when I get it.
Then I'll be sure to take handy dandy step by step pics of the installation process.
it was Christmas again when I got home tonight!
I'll get more pics this weekend while I'm strapping the HS6 and this filter to the car /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Here's the air filter that I ordered from SU-Filters.com
CLASSY!!! /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Doc - my best eyeball guestimation with a measuring device says it's 5/16" dia.
Most likely accurate. There are TONS of lever devices you can just clamp to it for linkage. The niggling bit will be the angle the cable has on it exiting the sheath so's not to "saw" thru the ferrule and jamb. You're into "Field Engineering" now.
A resourceful Marine will adapt, overcome. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
heheh...
I'm good at ... "rigging", or as my friend called it the other day while I was working on my B, "Performance modifications" /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I'm gonna have to find me a motorcycle shop for some filter oil, or is motor oil fine?
Whatever is in the crankcase will work in the carb. You can experiment with other stuff, but it isn't really much of a difference, IMO.
