R
RonMacPherson
Re: Dropping gearbox to replace fork pin, need gu
Randall's advice with the fingers is good, but you should try to see if a 3/8" inch extension, with the female end against the crank fits. If I remember I used one to line up the last clutch on my 6. Again like he says when tightening the bolts, try to center it, so that equal amount of splines are circumferentially equal.
