Wedge Dropped another engine in my TR7v8
philman
I set up another V8 for my TR7 (details unimportant) while the wife was visiting her folks I decided to drop it in while the garage was available. I couldn't get it started to clear the garage for her when she got back home. After she was home for a day it started right up. All I did was change a new set of NGK sparkplugs for a used set of Bosch plugs. You would have thought that at least one plug would fire. I think that my car missed my wife, even though she rarely drives it.
I battled an off and on hard start/ no start problem. Turned out to be the electronics in the stock distributor. Dropped in an old Mallory dual point I had laying around and no more problems. The thing that I couldn't figure out was the way it was so intermittent. Fine for days and then nothing. Hope your problem goes away on it's own.
me too.
Hot start is much more common. Do you have a high torque starter? If not, that should solve the problem. I can usually find a used one in a local junk yard for $40 or so, but there are tons of mid 90s Rovers in the yards around here.
Have one in my garage. But I don't think the one on the car is a stock unit as it is just a little bigger than the Hi Torque. This is a transplanted motor by Brad
The starter gets very hot down there by the cats. The TR8 originally came with a metal bolt on heat shield, as well as heat shields for the front half of the exhaust system, and a fiber heat shield for the underside of the tranny tunnel. I like to use the Bosch starters that come on the later Rovers. They are smaller, lighter and have more torque. They have a clip on heat shield that wraps around the main part of the starter. Once in a while you get lucky and find them still attached in the junk yards.
tr8todd said:
... I like to use the Bosch starters that come on the later Rovers. They are smaller, lighter and have more torque. They have a clip on heat shield that wraps around the main part of the starter. Once in a while you get lucky and find them still attached in the junk yards.
Sounds a lot like the one I have
Probably is - Brad's the one who put me on to the Range Rover starters.
Last time I looked for a rebuild or new one on line, some places were getting $400 plus for those original Bosch starters. $40 junk yard ones sound better.
I've got one of Woody's in a box. Guess I need to decide if I need to put it on.
