Wedge Dropped another engine in my TR7v8
philman
I set up another V8 for my TR7 (details unimportant) while the wife was visiting her folks I decided to drop it in while the garage was available. I couldn't get it started to clear the garage for her when she got back home. After she was home for a day it started right up. All I did was change a new set of NGK sparkplugs for a used set of Bosch plugs. You would have thought that at least one plug would fire. I think that my car missed my wife, even though she rarely drives it.
tr8todd
I battled an off and on hard start/ no start problem. Turned out to be the electronics in the stock distributor. Dropped in an old Mallory dual point I had laying around and no more problems. The thing that I couldn't figure out was the way it was so intermittent. Fine for days and then nothing. Hope your problem goes away on it's own.
philman
philman
me too.
DNK
Mine seems to have a hot start problem now.
tr8todd
Hot start is much more common. Do you have a high torque starter? If not, that should solve the problem. I can usually find a used one in a local junk yard for $40 or so, but there are tons of mid 90s Rovers in the yards around here.
DNK
Have one in my garage. But I don't think the one on the car is a stock unit as it is just a little bigger than the Hi Torque. This is a transplanted motor by Brad
tr8todd
The starter gets very hot down there by the cats. The TR8 originally came with a metal bolt on heat shield, as well as heat shields for the front half of the exhaust system, and a fiber heat shield for the underside of the tranny tunnel. I like to use the Bosch starters that come on the later Rovers. They are smaller, lighter and have more torque. They have a clip on heat shield that wraps around the main part of the starter. Once in a while you get lucky and find them still attached in the junk yards.
DNK
tr8todd said:
... I like to use the Bosch starters that come on the later Rovers. They are smaller, lighter and have more torque. They have a clip on heat shield that wraps around the main part of the starter. Once in a while you get lucky and find them still attached in the junk yards.
Sounds a lot like the one I have
Mickey Richaud
Probably is - Brad's the one who put me on to the Range Rover starters.
tr8todd
Last time I looked for a rebuild or new one on line, some places were getting $400 plus for those original Bosch starters. $40 junk yard ones sound better.
DNK
I've got one of Woody's in a box. Guess I need to decide if I need to put it on.
JPSmit Dropped off the engine for the Vauxhall last week Spotted 3
stretchit2 Oh No I Didn't or the Dropped Not Blues Austin Healey 6
ChrisS Almost dropped a valve Spridgets 7
BugEyeBear Healey-Abbott - For Sale - PRICE DROPPED!! Austin Healey 0
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
2wrench Dropped radio antenna into fender. Triumph 21
S Dropped off the garage space at Drew's yesterday Spridgets 1
healeyboz Dropped in the motor and transmission Spridgets 2
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
