    Thanks and welcome to BCF!
Dowell bolt position on Healey bell housing
bj7
I am currently restoring a BJ7 Heaely which unfortunately I did not dis-assemble. Is there a specific position for the 2 dowell bolts ( aec3487) on the bell housing ? There is a total of 7 bolts on the housing. I have restored E types and Mark2 Jags. before but a Healey is new to me.
:savewave: Welcome to the Forum. Post your question over on the Healey forum and I'm sure you'll get an answer.
Welcome to the group.
Take pics of your restoration.
I will look for your answer on the healey forum.
It will be nice to see pics or your restored car.
I'm a Triumph guy, know nothing about Healeys. But on Triumphs with "dowel bolts", the holes they fit in are considerably tighter tolerance than the remainder of the holes. You should literally have to tap them into place.
An ordinary bolt/hole has perhaps .020" of clearance for easy assembly, while for the "dowel bolts" to be effective at maintaining alignment, they should have less than .002" of clearance.
No idea if this is a problem for Healeys, but for Triumphs there are some vendors selling the wrong bolts. The "dowel" bolts are supposed to have precision ground shanks, long enough to fit most of the way through the rear plate and bellhousing. At least one vendor is selling ordinary bolts (which as usual have slightly undersize shanks). I wound up making my own from drill rod.
