Door Switch
Might work. Shame they don't give you the important dimension of how far the plunger has to be depressed to open the circuit.
I got door switches out of a junk yard SAAB 9000. They have worked very well for the past 5 years. The only problem was that I had to affix a rubber spacer to the passenger side door to actuate that switch.
I bought 2 from some place I cant recall right now but they fit the original hole and they had a self adjusting plunger when you closed the door the first time it pushed the switch in and then the the stalk move in if needed and it was set! and they work
Hondo
