Door/scuttle rubber seals
jandkellis
I have received seals from Moss and have the instructions offered by Roger Moment but I am struggling to get them installed; can anyone offer suggestions for installation short of removing the doors.
I would appreciate any help.
Thanks,
Jim "Red Rover"
I have never put a set of those seals in.
However, Removing the door is quite simple if that allows you to install them..
! ] You need a helper to steady the door as you remove the hinge from the body.
2] Use your floor jack with a heavy cloth pad over the saddle to support the door at its
normal height during removal and relocating to a safe storage site.
Re installation is the reverse of removal:glee:
