AUSMHLY
64BJ8. I'm assuming I'm not the first to meantion this. But it's pretty hard to roll up the driver and passenger windows.
I have cleaned and greased the entire remote control assembly and window channels in the door.
I've taken both vent window assemblys out, cleaned them. I brought them and both windows to a glass shop. We worked together to remove the black frame from the bottom and side of the windows. We installed new nylon door glass guides and reinstalled. Made sure that the metal frames were bent to match the glass, for a tight snug fit.
He says the glass curve is not exactly the same curve as the vent window channel. He said maybe the after market glass is off a bit. He can not find any vendor for Healey glass. Moss sells the same one I currently have, which has printed on the glass: UROglass-starglass-E9-43R-000471
It would appear I need to bend the vent track to match the glass. The track is consistant in width, with just a little rubbing. It seems I need to put more curve in the unit.
Yikes. How to do that without kinking, marking or making it worse. Suggestions? Or should I just work out more untill I (look like "Johnny Bravo" pictured on the left) don't need two hands to crank it. "Whoa Mama"
