door check strap
I think they all were mounted on top.
Nelson
The strap is on top on my Mk 2. There is a metal end cap covering the end of the strap.
K
kalist
Thanks for the info. I thought it went on top but wasn't sure. There were none on the car when I purchased it.
nomad
Supposed to be a little plate with a rounded end for the strap work on top of as well. At least on the later cars and I put them on my BE as well.
Kurt.
Nelson
This is a little fuzzy but it should give you some idea.
Millrat
Hmmmm. Not what I was thinking but that does give me a great look at what it should be. I wasn't around when the paint guys took the straps off but I don't think these were on the car. both straps were broken which led to some significant body work :frown:.
Thanks for the picture
Erik
nomad
Nelson gave you a nice picture of what is supposed to go over the strap but there is another little plate that goes under the strap. Check a Moss or VB catalog.
Kurt.
Millrat
So there are two pieces and the strap sandwiches in between? I will have to look through the bin of parts to see if they overlooked these. I will keep better track of Everything next time.
nomad
Yes, you've got it now, Erik.
Well aware of the damage that is done without these.
Putting the holes thru the strap can be a bear as well. I use a leather punch.
Kurt.
S Door Check Strap Austin Healey 5
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
sundown TR6 Door check strap Triumph 3
me61ic Forum search and Door Check Strap ? Austin Healey 1
Stinger TR4/4A TR4A Door Check Strap Spring Clip Replacement Triumph 4
W Broke check strap on door Triumph 4
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
F TR4/4A TR4 Question: Door check strap pin Triumph 5
Rob Glasgow Door Check Strap Austin Healey 12
M Door check strap repair Austin Healey 6
S door check strap attachment Triumph 15
6 door check strap Triumph 6
R TR4/4A Door check straps Triumph 7
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
KVH TR4/4A Door Check Straps Triumph 11
Michael Oritt Door check installation Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
M BN1 door check replacement Austin Healey 9
HealeyDave Door Check Friction Adjustment Austin Healey 12
sundown TR6 1973 TR6 door check straps Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
G 6 door check noise Triumph 13
A Door check Lotus 4
S TR2/3/3A door check straps for tr3 Triumph 1
mjobrien Door Check - Color? Austin Healey 2
S TR4/4A TR4 Door Check Straps Triumph 4
This14u Spitfire Spit Door Check Triumph 3
I TR6 Removing door check arm in TR6 Triumph 6
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
