Does stock fuel pump fall behind consumption?
tdskip
Hi guys - was looking at a Mini tech magazine and they had an article on fuel pumps. They suggested that cam driven pumps aren't capable of keeping up on modified/high performance engines.
Any truth to that on our TRs?
SkinnedKnuckles
I've not had any problem with a pump in good condition. That's with triple Z-S, GP2 cam, 1:1.55 RR, & about 9.3 compression.
Fuel filters, on the other hand, are a whole other issue...
tinman58
I would'nt think so. My engine is slightly modified and the carbs were running REAL rich. Black soot on the back of the car, smell of fuel out the tail pipe, The car ran good, but then a friend was behind me and we almost choked him to death going up to Mt. Hamilton. He complained and we adjusted the carbs leaner, ALOT. My point is that I think that the cam driven pumps will pump enough fuel no matter what. Race engines might be another story.
Twosheds
Kas Kastner told me that a TR3 race engine needs at least 15 gallons per hour flow.
Kas said it.
I believe it.
That settles it.
T
tdskip
Kas said it.
I believe it.
That settles it.
Wow - that is a lot of fuel.
Will a stock pump do that?
Twosheds
I dunno. It wasn't too hard to measure the flow of my electric pump, but measuring the flow from a stock pump would seem to be a little harder to do. Especially at max RPMs.
TR3driver
Great Pumpkin - R.I.P
15 gph doesn't seem like all that much, to me. 15*4 = 60, so that is a quart a minute, or 30 seconds for a pint ... that's about the standard I use for checking the stock pump at idle. I'm pretty sure it will deliver a lot more than that at higher rpm.
DougF
I'm using 3 Strombergs, all at stock factory settings with no problems. When tuning the carbs, at one point, they were all set very rich and I had no concerns. But I'm using a bit less than 15 gpm.
TomMull
I've never measured flow, although I'm sure Randall is correct and I agree that the stock diaphragm pump is adequate for street conditions. I also agree that it is fair to assume that the pump will be even more efficient at higher rpm - to a point. I don't know what that point is (certainly greater than 5000) but at very high rpms the diaphragm pumps seem to lose efficiency and starvation occurs. Tom
TR3driver
I agree the point certainly exists (although I don't know what it is either). It's basically similar to valve float, at some point the spring isn't strong enough to overcome the inertia of the lever & diaphragm before the cam comes around again. And unlike the valves, you can't just go to a stronger spring because that also changes the pressure.
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
Rut How does this happen? Spridgets 9
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
simon1966 Does anyone use 48 spoke wheels on a 100? Austin Healey 21
T TR2/3/3A Does your rotor wiggle Triumph 15
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
