TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them....
DavidApp
Got these from TRF a few months ago.
David
K
karls59tr
Bronze
I received a set of points locally that were in a Lucas box but did not have the Lucas marking? Although they resemble the Lucas points I believe they are an aftermarket brand. I also received a bush terminal lead and condensor that was supposedly Lucas But when everything was assembled on the dizzy the lead and condensor "ring ends" would touch the plate hold down screw. Would that not ground out the points? See my previous post for pics of the different ends. I don't think it's just the ends of the wires that is the problem but the shape of the bottom points plate as well.
LarryK
Watch what you buy as the aftermarket is full of correct looking boxes. If the box looks good but the points are not labeled be wary. The ends not being same shows you the difference and they may not last as long as the branded Lucas, Made in England.
TRopic6
For comparison, here is a set of NOS Lucas points from the 70s. "LUCAS" is in a unique font, with patent statement and "Made in England" stamped in the base. P1110672.jpg
D TR4/4A Lucas 23D4 vs 25D4 Distributor Triumph 4
lbc_newbie Lucas electronic distributor - do I need a coil? Spridgets 1
angelfj1 TR2/3/3A TR3A Lucas Distributor Triumph 6
19_again GT6 Lucas Distributor cap on Delco D204 Dizzy GT6+ Triumph 6
S Rotax - Lucas Distributor? Other British Cars 4
tosoutherncars Distributor question - Lucas 41216? Spridgets 1
T Is the Lucas distributor cap really 3 times better Triumph 9
MGTF1250Dave Lucas Distributor Rebuilt by Advanced Distributors Triumph 15
I Vacuum advance unit for BN1 [Lucas DM2 distributor Austin Healey 2
F Lucas distributor identification... Triumph 12
Tinkerman Lucas Distributor Cap Color Triumph 2
R "Lucas" Distributor Cap Needed Austin Healey 16
S Wedge TR7 Lucas Distributor Part Number Triumph 3
H Lucas Vs. Delco Distributor thanks Triumph 0
H Lucas VS Delco Distributor question Triumph 9
racing girl Lucas Distributor British Motor Corp 3
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
