TR4/4A Distributor Vacuum Manifold Hard Line
ghawk16
Can someone confirm something for me? The hard line that goes from the vacuum manifold on the distributor to the bottom carbs, how does the hard line plug into the vacuum manifold. Currently mine is flared a little so it doesn't insert into the hole in the manifold. When I screw the female union on to the manifold it bottoms out and I can then push and pull a millimeter or two on the hard line so it's not set nor is it sealed. How is the hard line supposed to go into that manifold and should it be an air tight fitting? Thanks
And of course my water drain tap on the side of the block that I bought from VB in 2015 is leaking along with my original heater valve (that one is my fault). Sooooo, going to have to drain the coolant to swap those out with new ones.
TRopic6
Hi Gary,
I've been pulling out boxes for eventual restoration of CT16696L. I bought an NOS hard line from Moss back in the 80s; you can take a look at it here. I think there should be a brass union that screws into the front manifold to fit the male fitting, but I don't have that part on hand. Of course, there could have been have been changes along the way. TR4 Vac adv line.jpg TR4 Vac adv line_Carb end.jpg TR4 vac advance line_Carb end.jpg
Jeff
sail
Not original but I just use a small piece of rubber tubing about an inch long that stretches over both.
G
ghawk16
Hi Gary,
I've been pulling out boxes for eventual restoration of CT16696L. I bought an NOS hard line from Moss back in the 80s; you can take a look at it here. I think there should be a brass union that screws into the front manifold to fit the male fitting, but I don't have that part on hand. Of course, there could have been have been changes along the way. View attachment 50981 View attachment 50980 View attachment 50979
Jeff
Thank you Jeff. That clears it up. It seems the piece flare at the end of the pipe that goes into the vacuum unit has...well...gone away. May have to go Richard's route below and use rubber hose unless I can find one.
TomMull
I think it's just a 1/8 in compression ferrule, available at a hardware or auto supply. Tom
G
ghawk16
I hope so! Just put in an order at Moss and didn't get it. Going to go to Orchard or Lowes today and see what they have. Thanks again for everyone's help. Once I get it running I'll have another question regarding horns. They are always on when the battery is connected. I suspect a ground but I double and triple checked the wiring and don't see it. I'll save that for later. First things first! Get. Car. Running!
TomMull
I think there is power to the horns all the time. The circuit is completed and the horn blows when the ground is connected through the horn button. I would suspect that the ground wire from the button is shorted somewhere.
Tom
G
ghawk16
Tom
Yeah, I thought the same thing so I looked at the wire connecting the metal portion of the steering column and didn't see it there. It's a new harness, but I'm wondering if putting the horns in they got grounded somehow? There is also a black ground wire under one of the two bolts on the passenger side horn. I just disconnected them for now and will whip out the voltmeter this weekend. See if I can find where it's grounding out.
charleyf
Gary,
Most of my horn problems have been caused by the electrical parts in the top of the steering column. Namely the brass ring that sits below the steering wheel coming in contact with the steering wheel or some other ground.
Charley
G
ghawk16
Gary,
Charley
I checked the ground there and it wasn't touching. But...I think it does have something to do with that brass ring as I damaged it and had to do a "fix". So we will see.
malbaby
I would try to obtain a little more clearance between the steering wheel and the upper outer column by lengthening the shaft slightly at the slip joint inside the engine bay.
G
ghawk16
Well, funny thing...steering wheel isn't even mounted! I'll dive into it after I get this whole engine running thing taken care of. Once thing at a time. Just scared the crap out of my dad and I when we went to put the power cable on the battery! HAHA
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
C TR4/4A TR4A with TR3 distributor and Vacuum Advance Triumph 4
V Vacuum retard distributor?? MG 9
marcm Non-Vacuum Distributor Spridgets 2
I TR6 69 TR6 distributor/vacuum advance/retard help Triumph 4
I Vacuum advance unit for BN1 [Lucas DM2 distributor Austin Healey 2
George Zeck Distributor / Vacuum Advance Q ....... Spridgets 11
E Distributor Vacuum Unit MG 4
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
M Accuspark distributor Spridgets 2
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
KVH General Tech Issues with Distributor--TR4 Triumph 13
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
M Mallory Dual point distributor Austin Healey 0
K TR2/3/3A Distributor Caps Triumph 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
K TR2/3/3A The Distributor Dwell reading... Triumph 1
W Mallory distributor on '60 BT-7 Austin Healey 4
