GregW
Ok 20-50, I wasn't sure if it would be a non detergent straight 30 or 40.
Those straight weights sound more like what some people put in the tranny/OD. Once again, answers will vary for that too.
Hi Guest!
Forget the Champion plugs and get a current Bosch or Japanese replacement. Bosh Platinum's are my choice. Agreed use a resistor type plug "R"
Not true. The resistance in the plug makes up for the lack of resistance in copper wire. Carbon wire has a significant amount of resistance to suppress noise in the radio (which I can't hear over my exhaust anyway). The resistance of the spark gap is way more than the plug resistor.Not sure how true but read the resistor plugs don't produce as much spark.
Oil: Castrol GTX 20W-50. I just checked the latest MSDS (Oct 2014) and zinc alkyl dithiophosphate (ZDTP, AKA ZDDP) is no longer listed as an ingredient, so my previous recommendations to not add ZDDP to it need rethinking.
It's not listed on their MSDS.Valvoline VR1 still has ZDDP last I checked if anybody is looking for an "off the shelf" oil suitable for our cars.
The fuel pump stops when the carb bowls are full. Usually, when the engine is running, the pump should run just enough to keep the bowls full. I can't describe the sound because I can't hear mine when the engine is running. When the engine is off, it will run to fill the bowls, then stop.....
I believe it's the fuel pump, it runs for a few seconds when I use starting fluid, it definitely is staving for fuel. I hear the fuel pump intermittently, shouldn't it be running all the time?
