Not totally on point, but there seems to be a gap where the pinch plate is on the distributor pedestal.
I actually had quite a problem tightening that plate recently. No matter what I did, the distributor would rotate under reasonable force. I actually stripped the nut and bolt on the pinch plate, trying to get it to squeeze the distributor more tightly.
I also note that Moss is supplying a different kind of pinch plate for the pedestal, at least that’s the case with some new distributors. Here’s a pic for you to review.
Let me know if you would trust it. It uses only one side for a bolt. Is this yet another instance where someone thought they had a “better“ idea?
