Ray,
You are doing great work. As I suspected, my descriptions are perhaps not that great. I decided to draw a quick circuit diagram to depict your configuration (as it should be) with the “P” disconnected and the dash bulbs grounded on the “P” side instead. I have attached the picture below:
The circuit depicts your circuit as described and assumes for example the right hand turn signal is selected. As you can see, there is NO VOLTAGE at FRB terminal #6 when turning right. The only voltages that should be present at the FRB are at terminal #1 (from the flasher “L” terminal), at terminal #4 (from the steering wheel switch) and this voltage at #4 swings the arm at terminal #3 across to short terminals #1, #2, and #3 together. This provides the flashing “L” voltage from terminal #1 to #2 and #3 which applies the voltage to all three right hand bulbs.
So, and this is important, if your design and wiring of your FRB is in accordance with the original phase 1 design and working as the original box did, there cannot be voltage at #6 when you select a right turn and hence nothing at the left dash bulb. I can only conclude there is an issue with the build or installation of your FRB.
Best of luck on your quest.
Cheers
Tony
Cheers
Tony
Hi Guest!
