jtb55
I am replacing the differential in a latter hypoid type rear axle. I have reviewed the service manual. I will remove the axle shafts and then unbolt the existing diff, bolt in the new one. Because I had no issues prior to the change I expect to only replace the gaskets, o rings and oil seals. It seems straight forward but since I have never done it. Any thoughts as to what I might encounter. thanks jtb
