The pinion oil seal has developed a slow leak on my 390 rear end. Is there a replacement oil seal that can be found at a NAPA store or will I have to order one from the usual suppliers?
Thanks,
Charlie
Thanks,
Charlie
spritenut said:I did get one from the local auto parts store, my guy is old school, he uses a book, not a computer and cross referenced it to a full size Ford rear axle seal.
Unfortunately, I do not have the part number.
If my memory serves me, it was a 73 (ish) Crown Vic or LTD.
nomad said:Give them a call. Just got one from my local O-reileys. Heed what Kellysguy said. I've used a torque wrench and not quite tightened to the book spec when refitting. If you overtighten you will ruin the correct gear lash setting.
Kurt.
