Difference between an HIF6 and HIF44?
Billm
OK- as the title says- what is the difference between them or is there even an HIF6 or only an HIF44?
I have a couple of HIF singles (no provision for coupling shafts)that have a 1.75" throat, what are they?
BillM
I ran a single HIF6 from an Austin Marina on my 1978 MGB for several years (1992-1998) before switching over to dual HS4s.
The HIF6 is a 1.75" throat.
Hap can probably chime in as to what the exact differences are between the two carbs.
Hi,
The only difference between the 6 and 44 is that as Rick has said the 6 has a 1.75" throat and the 44 a 44mm throat. Most parts are interchangeable ( floats,jets etc ) although the throttle discs are slightly different.
Skip
skiptune said:
Hi,
Skip
Welcome to the BCF, Skip!
:cheers:
Mickey
