Keoke,
As we have already had this discussion, I don't understand why you keep promoting the use of a conductive grease for application in the Healey?
I have suggested the use of dielectric grease for use in electrical connections on the Healey but only see the use of a conductive grease as risky at best. Where a conductive grease will promote a circuit any where it may flow as a result of heat or being misplaced (as from a finger print), a dielectric grease is a non-conductive that will assist and support circuit insulation, lubricate the connector, and retard flash and corrosion. However, it will easily move aside to provide a solid electrical connection when pressure is applied as in the incursion of a connector.
I totally agree with Tahoe and suggest that conductive grease is very carefully evaluatred before use in a Healey application.
Ray(64BJ8P1)
