martx-5
OK, I got the crank in with the pistons and put the cam, which is original, but regound for more duration and lift. I lined up both gears etc. up to the original marks. I then used a degree wheel to check the cam timing against what the cam grinder said it should be. I used the timing at 0.050" lift method. Chart said at 0.050" intake lifter rise, cam should be at 9 deg. BTDC. I'm getting closer to 12 deg. BTDC. Same amount is out on the closing...about 3 deg. sooner.
Looking in the original TR3 service manual, it mentions that you can adjust the cam timing by 1/4 tooth intervals. There are 42 teeth on the cam gear. Now for the question...
Is that 42 tooth interval divided into 720 deg. (then divided by 4, resulting in slightly more then 4 deg.) or a 360 deg interval (resulting in slightly more then 2 deg.)???
Am I all out of whack here, or should I try to get this cam timing closer??
