DEAD PEDAL for a BT7
petnatcar
I got tired of my foot flopping around in the footwell so I fabricated this support pedal.
Use .080" aluminum sheet stock to make the pedal and 1 or 2 self tapping screws to attach it to the kick panel.
You'll need to drill through the kick panel into the metal of the footwell side panel.
A good metal shop can make this in 30 minutes or less using the attached full size pattern. (Based on 8.5 x 11 paper)
Cut and stick 2 strips of 3M Non-Skid material on the surface of the pedal.
This mod will leave 1 or 2 holes in the kick panel but the support you derive when cornering should override that drawback.
P
petnatcar
I screwed it next to the little vent flap on the cross member. You can just see the pigtail coming out of the firewall and curving up to the right past the vent.
I have to use my hand to push it but I hardly ever drive the car at night anymore and the dead pedal is still worth the inconvenience.
Gearhead_Garage
I like the idea of a dead pedal and I hate the location of the dimmer switch. It seems like a bad idea to have your left foot below the pedals because it is hard to get them back into position in a hurry.
Could you relocate the dimmer switch to the upper portion of the deal pedal? That would seem like an ideal spot.
P
petnatcar
Hi Glenn,
My foot is not below the pedals but on the same plane as them. I've been thinking about incorporating the dimmer switch into the top part of the pedal but it isn't a priority.
Gearhead_Garage
I really disliked the placement of the high beam switch in my BJ8 and wanted a dead pedal so I designed one and printed it on my 3D printer using a carbon-fiber infused plastic. It is very solid, uses the factory screw holes for the dimmer switch to mount the pedal, and relocates the high-beam switch to the top of the pedal where it is still convenient but out of the way.
I think it turned out really well. If you would be interested in having one of these, PM me.
Gearhead_Garage
That looks great, Glenn! 3D printing has fascinating potential, and it's interesting to see a Healey part made that way.
Thanks. It is a real game changer when you can envision something, create a virtual model, and then click a button and presto (5 hours later in this case) you have the exact thing you imagined.
I am making a few other Healey improvements that I will share when they are complete. If anyone has ideas let me know.
steveg
View attachment 46635View attachment 46636View attachment 46637View attachment 46638View attachment 46639
Very nice! Simple solution moving the switch up out of the area of the dead pedal.
Note - it requires the BJ8 dip switch and mounting bracket & wouldn't fit earlier cars as-is.
dougie
My well used and hard pressed dead pedal, it's a must in any vintage racing Healey.
Gearhead_Garage
Thanks for the note. I will have to study some other cars to come up with solutions for them.
Steve--
You said: "Note - it requires the BJ8 dip switch and mounting bracket & wouldn't fit earlier cars as-is"
I am interested in Glenn's pedal for my car and wonder if you can enlarge on your statement. What is different about the 100 that would make it so--in the Moss catalogue the same part number is given for all cars, 100 to BJ8:
Austin-Healey 100, 3000 Electrical System 542-130 SWITCH, headlamp dip
Duane_Rhynard
The two brackets and switches are different:
BJ8 Bracket
BN1-BJ7 Bracket
BJ8 Switch
BN1-BJ7 Switch
R dead pedal for '74 midget? Spridgets 4
HealeyPassion Dead pedal and pedal positioning project paper Austin Healey 3
HealeyPassion Dead pedal for 5 speeds Austin Healey 5
K TR2/3/3A TR3 "dead pedal"? Triumph 9
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R How old is "dead" FORUM Help 5
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
FlyingCat Spitfire Dead Starter? Triumph 18
Sopwith_Camel dead at the finish line Spridgets 10
6 Dead Circuit ARRGH! Spridgets 13
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
L TR6 need help on long dead TR6 Triumph 16
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
T TR4/4A Flat/dead spot on the starter? Triumph 5
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
GTP1960 TR2/3/3A Fuel pump inertia switch vs. dead engine switch? Triumph 14
JPSmit Truck diagnostic advice needed [I suspect it is dead!]] Other Cars 7
sim Dead spark plugs ? Spridgets 52
JPSmit Sometimes I am surprised I am not dead Spridgets 15
P Turning to Top Dead Center Austin Healey 11
RickB All 4 parking lights dead, fuses all good? Spridgets 6
dklawson Alex Moulton Dead at 92. - 12/10/12 British Motor Corp 1
NardisCNC DEAD Battery Question...... Spridgets 12
D Dead Boot -- What do you know about this ? Jaguar 6
G DEAD BATTERY Austin Healey 4
M Top Dead Center Triumph 48
L I see dead cars... Austin Healey 9
D Car seems to have a dead battery [I no it's good] Spridgets 13
G GRRRR -- Dead in the water again!! MG 6
DanNagy Spitfire Jumping a dead battery on a Spit MK1 Triumph 7
S Wedge TR8 starter dead spot? Triumph 26
G Gauges dead after wash Spridgets 6
vping Dead battery or Genny gone south? MG 8
davester The Prince of Darkness strikes! Dead starter MG 15
KVH Triumph Activity Dead on Ebay Triumph 8
JPSmit Top Dead Centre Question Spridgets 24
C Dead Again... Triumph 25
T Crypt car driving in the dead of night Triumph 10
2wrench Number 1 cylinder, top dead center Triumph 51
Shealey OT: Boyd Coddington Dead at 63 Spridgets 10
beaulieu TR6 TR6 project with one dead cylinder ? Triumph 10
Nunyas Dead in the water... MG 22
B MGB MGB Cuts out, Tach goes dead..... MG 18
Z Charging/Dead Battery Problem Spridgets 8
W Dead tach MG 5
T Crypty's dead carbs Triumph 52
T 26 miles-Crypty's dead,again Triumph 39
G Fixin to wake the dead tonight....a question first Triumph 11
zimmy new,....dead battery Latest Spridgets 1
