V
vagt6
The dashpot oil in both of my MKIII Midget's SU HS2s seems to leak out rather quickly. It's gone every time I check it, about once per week or just about every time I drive the car.
However, after reading SU diagrams I noted that I do <span style="text-decoration: underline">not</span> have "damper gaskets" on either carb, or at least I can't see any. Also, I'm using 3-in-1 oil for dashpot oil.
Would either of these things cause a dashpot oil leakage problem? I've ordered the damper gaskets from Moss, along with the Moss SU damper oil (4 oz. for $12, ouch!). I'll install the damper gaskets ASAP.
<span style="font-weight: bold">Question</span>: do the damper gaskets simply fit between the plastic damper cap, and the neck of the suction chamber?
I wonder if the absence of the damper gasket is the source of my oil leakage problemo???
Viewing the exploded SU diagrams, I don't see any other gaskets that hold in the damper oil. Where would the damper oil go if and when it leaks????
Damper oil gremlins (well, it is almost Halloween!
