Hi Guest!
Roger said:Sorry, Doc, but that's a popular misconception!
Certainly the dampers reduce the speed of lift of the pistons, but the reason for that is that if they fly up too quickly, depression across the choke is lost and far from having a mixture that's too rich, you have one that's too lean. Fuel won't be dumped down the throats, it'll barely struggle its way out of the jets, even though the taper of the needles means the apertures are enlarged. Just the opposite of what you wrote, in fact. Ivandyke got it right in his post.
walshja said:man, I can't seem to get a grasp of carbs and all their components. Wish there was a class I could take on this.
using this picture, where should the oil level be?
https://www.mgbexperience.com/article/images/su-hs4-section.gif
and I am guessing it is better to have more oil, then being low? since any extra oil will disappear?
thanks for all the, close to 20 words, descriptions !
