Dashboard Interchange: Alpines
pmenhusen
Will the dashboard out of my '67 Alpine parts car fit into my '63 Series III? How difficult is it to remove the dashboard?
thegoodbeamer
It will fit as they are basically the same.The roll trim at the bottom of the dash must first be removed. It is held in place at three points which are easy to see if you look under the dash. Th center cover piece under the steering column must be removed first.Undo the column holding bracket and to give you some room. disconnect the wireing. remove the screws holding the dash which you can see from the front and remove.The 63 is still positive ground and 67 is negative ground so you may want to use the 63 gauges.
MikeP
Removing the dash will take several steps.
1 Remove the lower crash pad. It's fastened at each end at the door opening, under the steering column, and by two thru studs right above each side of the transmission tunnel.
2 Remove the steering column cowl and turn switch.
3 Remove the steering wheel. This may not absolutely need to be done but it sure makes things easier.
4 Remove the 4 screws securing the dash to the body, one on each side and two at the top inline with the lower crash pad studs.
5 Remove the switches and gauges. This might be done earlier in the process, it's up to you.
6 The dash should now drop partially free. You'll now need to reach in at the top and remove the slide switches for the heater/demister. They're 5/16 heads if they haven't been changed by a dpo. This can be a tight fit and you may not be able to see much. It'll take a wrench and socket or two sockets since it's a thru bolt with nut. There are three or four of them on the plastic dash.
7 Dash should now be able to be pulled free, although you might have to jiggle it around a bit.
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
JohnGone MGB Wood Dashboard Kits MG 1
L Replacing veneer on wood dashboard Restoration & Tools 14
ckeithjordan TR2/3/3A Dashboard Covering Edge Clips Triumph 13
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
J Attaching new BJ7 Dashboard To Body Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
K For Sale MG Midget Dashboard with Gauges Spridgets Classified 3
J BJ& MK ll 3000 Dashboard Austin Healey 2
A For Sale TRIUMPH 74 TR6 Dashboard w/Guages Triumph Classifieds 7
S TR4/4A How to finish dashboard? Triumph 19
Joe_Healey BN2 dashboard silver Austin Healey 0
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
T Dashboard Knob Removal Spridgets 1
A TR6 Lettering on 1971 dashboard Triumph 1
wkilleffer MGB Dashboard pad replacement issues MG 3
AHS 1968 steel dashboard - can anyone confirm? Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
S Dashboard toggle switches for BJ8 - exact match? Austin Healey 12
K TR4/4A TR4A Dashboard Veneer? Triumph 13
K TR4/4A Veneering A TR4A Dashboard? Triumph 0
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
B Dashboard Warning Lights Austin Healey 8
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
AHS TR2/3/3A Dashboard hole identification Triumph 8
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
TR6BobNF TR6 TR6 Dashboard Hinge Question Triumph 3
R 100-4 dashboard color Austin Healey 1
R 100-4 dashboard removal help Austin Healey 4
Lbp TR2/3/3A New to Forum, New TR3 Owner, Dashboard Question Triumph 8
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
pkmh Removal and Refinishing BJ8 Wood Dashboard Austin Healey 41
Grannieannie Somerset dashboard Other British Cars 5
Patrick67BJ8 Additonal Gauge[s] for BJ8 Dashboard Austin Healey 13
Xte Original covering center dashboard and top dash ? Austin Healey 5
R Recovering BT7 dashboard Austin Healey 5
H Healey 100 Dashboard Color Austin Healey 10
Zimmycobra TR4/4A TR4A Dashboard question Triumph 5
af3683 Kienzle Dashboard Clock Triumph 10
Patrick67BJ8 Additional Gauges to a BJ8 Dashboard Austin Healey 6
middie Late model dashboard Spridgets 3
Zimmycobra Dashboard air vent grills Triumph 1
BugeyeNJ58 New gauges in Dashboard where radio goes... Spridgets 5
