Removing the dash will take several steps.
1 Remove the lower crash pad. It's fastened at each end at the door opening, under the steering column, and by two thru studs right above each side of the transmission tunnel.
2 Remove the steering column cowl and turn switch.
3 Remove the steering wheel. This may not absolutely need to be done but it sure makes things easier.
4 Remove the 4 screws securing the dash to the body, one on each side and two at the top inline with the lower crash pad studs.
5 Remove the switches and gauges. This might be done earlier in the process, it's up to you.
6 The dash should now drop partially free. You'll now need to reach in at the top and remove the slide switches for the heater/demister. They're 5/16 heads if they haven't been changed by a dpo. This can be a tight fit and you may not be able to see much. It'll take a wrench and socket or two sockets since it's a thru bolt with nut. There are three or four of them on the plastic dash.
7 Dash should now be able to be pulled free, although you might have to jiggle it around a bit.
