Dash Lighting [cost and access of incandescent Bulbs]
RAC68
Hi All,
Well, maybe now is the time to investigate and change dash lighting in my Gauges. Recently, I had an Incandescent bulb actually come apart and it has only been a little over 50 years. However, searching for a replacement seems to indicate it would be less expensive and a brighter idea to change to another lighting approach as I have found finding original-type bulbs to be difficult to find and, when found, has grown quite expensive (with the addition of shipping and handling).
Although I would prefer to just replace the original incandescent, has anyone tried Electroluminescent Tape (EL) installed inside the gauges? Also, can any supply search specifications for e10 base LEDs bulbs for gauges and indicators?
Any ideas and information would be appreciated,
Ray(64BJ8P1)
dancrim
HiPo Garage has LED's in many styles, however they are a little high on prices. Good Info there on dash
lights. You need a a bulb that will dim. Read the Tech. section on dash lights. They will also brighten up
the dash lighting.
gonzo
LEDs are a great and brighter option and are available for POS and NEG ground 12V systems. I purchased a set off e-bay. Do a search and look for Tiger1a seller. He's the primary source for our major suppliers. e10 based LEDs "plug and play" ready for all gauges and directional lamp(s). Incandescent bulbs still in place for my warning lamps. Rather than pure white, these LEDs emit somewhat blueish, but that's fine since our gauges have blue collars and the directional housing is green. GONZO.
Mert
I installed LEDs (Superbright) on every gauge and indicator lights on my BN7. I had a positive ground and was able to exchange the LEDS making sure which side of the wiring was neg / pos. Superbrights (St Louis) has everything you need. I put LEDS in the parking lamps, rear lights, high beam, turn signals. Only one you cannot replace is the generator power (red) light. Mert
Deleted member 19315
I, m considering this change to LED dashlamps too so am very interested in the thread. Mert did you experience any flashing rate problems with changing the turn signals? I'm not sure how to progress with my 100/6 which has combined rear lights turn signals and brake lights in the rear and combined turn and side lights at the front. I can easily source an LED equivalent to the twin filament incandescent currently used but and worried I may make myself a world od problems I don't have time for ?
Andy
RAC68
RAC68
Thanks All for your quick responses. Do you have any numbers for or specifics for the bulbs you have installed. My BJ8 is negative ground and I did look at the MOSS catalogue but, of the 2 models they picture (and extended bulb and a flat bulb) which one did you choose. What did you ask for and/or order?
Thanks again,
Ray(64BJ8P1)
blueskies
Not everyone likes the same thing, but I have been known to remove LED lighting on a vehicle that did not come with it originally. On a nice original or restored Healey, aftermarket lighting may hurt the value.
An exception would be if LED or other after-market lights can improve the brightness and safety of the front and rear lights; then safety considerations would outweigh correctness. (I love the LED and HID driving lights on my F350)
Mert
If you put in LED on the front and rear lights, you will need another flasher unit. My challenge came with the positive ground issue. You will need two in line resistors (RL-650), 1 - FL-3 LED flasher relay, 2 each 1157-R18-T Red LED bulbs, dual intensity 18-MSD LED tower (non-polarity) and same data for a set of 2 Amber LED. What is listed here I still have left over from my conversion. I also have some electro-mechanical flasher units that will work better in lieu of the FL-3. I have sold my AH BN7. It is now in England. So these items are available, it anyone is interested. Do NOT buy any LED kits from "12".. Super-bright was/is my main source of all types of automotive lighting issues.
Mert
I forgot to mention, due to my AH being with positive ground, I ended up buying LED disc boards for both the front and rear lights. The source of these is the following Classicautoleds.com He is in Oregon. You will still need a new flasher, the resistors if you purchase a set from him (I believe his name is David). These kits are not cheap. But he guarantees the work. He called me from Oregon when I was putting the LED boards in my AH. Worth the $$ for me. I was going no where with the positive ground polarity. He resolved the issue. But the LED from Super-bright will work just fine and are not as expensive, as I mentioned in the last posting.
Patrick67BJ8
Increased the exterior park, turn and brake lights by using halogen light bulbs I got from BCS. My phase 2 has the parking lights so I left them as they were as the 20 watt clear bulb would have been too bright. all I had to do was swap out the bulbs! The brake light bulb was a special wattage that BCS seems to be the only one who has them. No flasher changes needed.
steveg
Bought these for my dash lights. <$4 each:
https://www.ledlight.com/e10-screw-9-5050-3-chip_12_vdc.aspx
Will report back when installed.
John Turney
I found that painting the inside of the housing of the gauge white made a significant increase in brightness. My tach was painted light blue inside and the white made it much brighter.
Keoke
Guys, you don't want your cars to look like pimp mobiles!
Well Yeah!!-But: IMOP
If you drive long distances you are not going to want all that brightness in the cockpit at night.
I Used the same scheme as JohnBN4 above
Patrick67BJ8
Be careful with halogen bulbs inside plastic lens caps. They put out a bunch of heat.
The 20 watt bulbs have been tested with no problems by BCS and the 50 watt bulbs for the brake lights as well. Fortunately the brakes are not on very long.
AUSMHLY
Back in 2008 I ventured into this topic of gauge bulbs
https://www.britishcarforum.com/bcf...e-with-LED%92s&highlight=brighten+dash+lights
The easiest modification to better illumination of the gauges is to add another 2.2w incandescent bulb in the bottom of the tachometer and speedometer. That will balance out the top light and the entire gauge will now be lit up more uniform. Very easy, buy another bulb holder and bulb, drill the hole in the back bottom of the gage, insert bulb holder, splice into the top bulb wire, done.
The fuel and water/oil gauge, replace the 2.2w bulb with a 4w long shaped bulb.
The directionals, high beam and ignition, replace with a superbright led bulb.
AUSMHLY
How can we see the pictures in the old article?
I guess some of the pictures are not there anymore? Page 8 in the old article (link) has some of my prior photos.
Here's one photo from page 8 that shows the following:
Fuel, 4w incandescent
Oil/water, 4w incandescent
Speed, (2) 2.2w incandescents
Tach, (2) 1w superbright LED's (to show the difference)
Below shows 2.2w in tach/speed and 4w in fuel/oil
Below shows where I added the second bulb (brass with red wire) in the tach/speed
These are the bulbs
RAC68
RAC68
Hi All and thank you for all the responses.
Roger, I was initially looking for your earlier posting as I was having difficulty finding the incandescent bulb replacement and thought it would be a good time to go LEDs. However, I must admit I like the 2-bulb incandescent look as they produce a more intimate presentation that, I feel, is more consistent with the age of the cars. Since I now drive my Healey very infrequently at night, bulb longevity is less important to me but a clear presentation is. I believe I will take your suggestion and consider installing LED bulbs to illuminate the dash directional indicators.
Thanks again,
Ray (64BJ8P1)
Boggsy64 MGB Dash lighting question MG 4
B dash lighting options Triumph 5
K Dash lighting Austin Healey 2
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
