My BJ8 has developed a miss. The exhaust for 4,5,6 cylinders doesn’t have a smooth rhythm like the 1,2,3 cylinders.
I decided to do a compression check and my 1,2,3 cylinders are 170 lbs and my 4,5,6 cylinders are 160 lbs. i spun the engine for five compression cycles for my readings. I used a new compression tester for the tests. Is there a special procedure for doing a compression check on the Healey because of a difference between the front and rear carbs?
I use a Pertronix in my dizzy, red rotor from Advanced Distributers. Top loader cap, Bosch blue coil. Advanced Distributors rebuilt my dizzy and a spare I had which is for points.
I’ve been told that my plugs look like my engine mixture is too
