Bob_TR6 said:Hi Todd:
I wanted a trigger wheel that fit on the <span style="text-decoration: underline">back</span> side of the harmonic balancer--out of the way--like stock fitments do. I couldn't--at the time--find anything that would work the way I wanted, so I drew a few things up, had my friend (with a laser cutter)cut me out one or two basswood blanks to check fit, and then sent the file off to a waterjet company to have executed in steel.
It still took a little fine tuning around to fit. :frown:
That said, I've got no idea if the trigger wheel for an Econoline would've fit as nicely.
But I'm happy with the way it looks. With the exception that the timing indicator pointer had to be cut--the trigger wheel spins through that space.
FWIW, I've fitted Megasquirt to control the ignition--along with adapters from Patton Machine for the fuel injectors :wink:
Hi Bob,
The Econoline one is big and bulky and ugly. Your solution is probably much more elegant.
Thanks and cheers!
Todd
